Group: DynoMotion Message: 3015 From: fireup_kev Date: 1/9/2012
Subject: Re: M Code in KMotion_dotNet
I don't see that these features are exposed in KMotion_dotNet. When I it sees an M6, it should at lease pause and allow the event to happen and then allow a way to continue, but it just zips right through it...
Kevin
> Hi Kevin,
> Both are possibilities. The functionality that is shown on the KMotionCNC Tool Setup Screen allows such things as setting bits and calling a C Program in KFLOP. But there is no screen to help set it up. You must configure the information programmatically. The information is stored in a table of "MCode_Actions". I haven't looked at if/how it is exposed in KMotion_dotNet. There was also a new type of action that can simply make a call back to you to do whatever you want.
> Sent: Monday, January 9, 2012 9:35 AM
> Subject: [DynoMotion] M Code in KMotion_dotNet
> How is M Codes handled in KMoiton_dotNet? When it sees a M6 for example, does it send a callback, call a C Program in KFLOP?
> Thanks,
> Kevin
Group: DynoMotion Message: 3021 From: Tom Kerekes Date: 1/9/2012
Hi Keven,
Well, no if no "Action" is defined for the MCode then the Interpreter simply does nothing.
I guess the thing to do is to add a "SetMCodeAction" function to KMotion_dotNet where the MCode number, action code, 5 doubles, and a string would be passed in to define the Action.  Actually this is required to set the Action to M_Action_Callback to even get the callback.
The only workaround at the moment short of adding that functionality would be to hard code the MCodeActions on the C++ side.
// This structure defines the action and
// parameters for a particular MCode Action
typedef
struct
    int Action;
    double dParams[MAX_MCODE_DOUBLE_PARAMS];
    char String[256];
} MCODE_ACTION;
Group: DynoMotion Message: 3022 From: Brad Murry Date: 1/9/2012
I should have the implementation complete by tomorrow.
-Brad Murry
Sent: Monday, January 09, 2012 4:29 PM
Subject: Re: [DynoMotion] Re: M Code in KMotion_dotNet
Hi Keven,
typedef
struct
    int Action;
    char String[256];
} MCODE_ACTION;
Sent: Monday, January 9, 2012 12:16 PM
Subject: [DynoMotion] Re: M Code in KMotion_dotNet
Kevin
> Hi Kevin,
> Thanks,
> Kevin
Group: DynoMotion Message: 3025 From: fireup_kev Date: 1/9/2012
Thanks Brad,
How do I use the UserCallBack, it doesn't seem to be doing anything when I activate it.
> -Brad Murry
> Hi Keven,
> typedef
> struct
> int Action;
> char String[256];
> } MCODE_ACTION;
> Tom,
> Kevin
> --- In DynoMotion@yahoogroups.com <mailto:DynoMotion%40yahoogroups.com> , Tom Kerekes <tk@> wrote:
> > Hi Kevin,
> > Â
> > Â
> > From: fireup_kev <kliboon@>
> > To: DynoMotion@yahoogroups.com <mailto:DynoMotion%40yahoogroups.com>
> > Â
> > Thanks,
> > Kevin
Group: DynoMotion Message: 3026 From: Tom Kerekes Date: 1/9/2012
Hi Kevin,
I'm not sure which one you mean.  But there is a special GCode User Callback Set_G_USER_CALLBACK that is triggered in the form of a special Comment.  It returns the string portion of the comment as a code you might use to know what to do.  The form is:
(USR,My String)
There is a C example of its use in the SimpleGCode Example.
Group: DynoMotion Message: 3027 From: fireup_kev Date: 1/9/2012
Ok, I understand now. I didn't realize that there has to be
"(USR, message_string)" in my G Code for it to work.
Kevin
> Hi Kevin,
> (USR,My String)
> Sent: Monday, January 9, 2012 8:54 PM
> Thanks Brad,
> > -Brad Murry
> > Hi Keven,
> > typedef
> > struct
> > int Action;
> > char String[256];
> > } MCODE_ACTION;
> > Tom,
> > Kevin
> > > Hi Kevin,
> > > Â
> > > Â
> > > Regards
> > > Â
> > > Thanks,
> > > Kevin
